Smooth Polygon with circular arcs ("arc spline") only
1052
11-06-2020 08:56 AM
GarretDuffy
Can anyone advise on a technique or approach to smooth a digitised polygon using only circular arcs, or "arc splines", and not bezier or spline curves?  I am trying to smooth a polygon where a circular arc is best approximator to the real-world source of the shape of the polygon (the shape of the polygon is from a vehicle that is turning on circular arcs).  The Smooth Polygon tool uses bezier curves which is not an accurate model for the polygon shape.
Thanks!
