Slow geocoding on locator stored in SDE
1214
09-18-2013 12:00 PM
MatthewBaker2
All,
I've created a single field locator in our SDE based on an SDE point file of ~280,000 points.
When I geocode against this locator, the performance is *extremely* slow.
When I create the locator in a folder on my hard drive, based on the same SDE point layer, the performance is much faster - or normal.
I can't find anything regarding storage of a locator in SDE. I'm wondering if I'm missing a setting, perhaps a configuration keyword, that would speed things up a bit.
product versions:
- ArcGIS version 10.1
- SQL Server 2012
Any thoughts appreciated!
Thank you,
-mb
BruceHarold
Esri Frequent Contributor
Hi
Your observation - that file-based locators are faster - is correct.  Esri recommends file-based storage of locators if you want performance.  The use case for SDE storage is the rare situation where you have frequently updated reference data also used within a locator.
Regards
JoeBorgione
A couple of years ago it was recommended to me to keep locators out of a geodatabse.  I keep them in local and or network drives.  They often reference SDE feature classes or they may reference replicated data in a fgdb located in the same local or network drives.  Everything I do is in ver 10.0.  I dont have a point feature class nearly that big though.
My suggestion is go with what gives you the best performance; one way replication works very well for me where I store and maintain feature classes in the SDE but use them in a fgdb.
BruceHarold
Hi
Regards
