Slope Tool for Bathymetry
2507
11-19-2022 09:10 PM
Labels (3)
MShairah
Hello!
I was wondering if the Slope Tool can be used for bathymetry points (negative elevation values) ?  What would the slope values look like? I was unable to find any related tool in the Bathymetry Toolbox.
Thank you.
DanPatterson
You could always do a comparison to understand first hand.
First calculate slope using the original elevations/depths.
Second take the absolute values of the inputs to make the inputs positive, then calculate slope.
Take the difference between the two slope rasters.
What do you see?
... sort of retired...
MShairah
Hello Dan,
Thank you for your response. I've done as you suggested and these are the results. The green areas (low slope) are more or less the same for both rasters. However , the red areas (slope values greater than 10) are more pronounced and cover a bigger area when using the absolute value of the depths. I wonder why this is so.....
DanPatterson
Your mins and maxs are different.  check that your raster properties were the same eg. raster type, cell size, alignment etc were the same and you may have to fine-tune your classification.
Also, subtract the two ... that is where you will see the differences and their magnitude
