shp2sde file attribute loading issues
2756
6
08-09-2011 06:03 AM
BartPittari
I'm trying to automate a routine that imports data from a Shapefile to SDE.  The old data in the SDE layer needs to be wiped away each time, so I am using the 'init' option in the shp2sde command.  Since Shapefiles notoriously truncate field names, I am trying to use the '-a' option that loads a file map of the names and other info.
shp2sde -o init -l pittarib.polyfeature,shape -f polyfeature -a file=poly_feat_attr.txt -r poly_feat_rej -v -i esri_sde_devtest -s testserver -u pittarib -p mypassword
Doing a lyrinfo command on the shapefile yields this information:
OBJECTID OBJECTID SE_INTEGER 0 -
SDE_FEATUR SDE_FEATURE_DATE SE_DATE 0 -
TEST_LINE_ TEST_LINE_PART_COUNT SE_INTEGER 5 -
TEST_POINT TEST_POINT_PART_COUNT SE_INTEGER 5 -
TEST_THREE TEST_THREE_POINT_COUNT SE_INTEGER 5 -
SDE_POLY_P SDE_POLY_PART_COUNT SE_INTEGER 5 -
SDE_CLOSEP SDE_CLOSEPOLY_ERR_FL SE_STRING 1 -
SDE_MULTIP SDE_MULTIPART_SHP_FL SE_STRING 1 -
SDE_INTERS SDE_INTERSECT_ERR_FL SE_STRING 1 -
AREA AREA SE_DOUBLE 27 8
LEN LEN SE_DOUBLE 27 8
OBJECT_ID_ OBJECT_ID_FK SE_INTEGER 0 -
OBJECTID N 10 - SE_INTEGER 0 -
SDE_FEATUR D 8 - SE_DATE 0 -
TEST_LINE_ N 5 - SE_INTEGER 5 -
TEST_POINT N 5 - SE_INTEGER 5 -
TEST_THREE N 5 - SE_INTEGER 5 -
SDE_POLY_P N 5 - SE_INTEGER 5 -
SDE_CLOSEP C 1 - SE_STRING 1 -
SDE_MULTIP C 1 - SE_STRING 1 -
SDE_INTERS C 1 - SE_STRING 1 -
AREA N 19 8 SE_DOUBLE 27 8
LEN N 19 8 SE_DOUBLE 27 8
OBJECT_ID_ N 10 - SE_INTEGER 0 -
SDE column definition string:
OBJECTID integer, SDE_FEATUR date, TEST_LINE_ integer(5), TEST_POINT
integer(5), TEST_THREE integer(5), SDE_POLY_P integer(5), SDE_CLOSEP
string(1), SDE_MULTIP string(1), SDE_INTERS string(1), AREA double(27,8),
LEN double(27,8), OBJECT_ID_ integer
The attribute info on the SDE Layer in ArcCatalog yields this information:
OBJECT_ID_FK / Data type: Integer / Width: 4 / Precision: 10 / Scale: 0
SDE_FEATURE_DATE / Data type: Date / Width: 36 / Precision: 0 / Scale: 0
TEST_LINE_PART_COUNT / Data type: SmallInteger / Width: 2 / Precision: 3 / Scale: 0
TEST_POINT_PART_COUNT / Data type: SmallInteger / Width: 2 / Precision: 3 / Scale: 0
TEST_THREE_POINT_COUNT / Data type: SmallInteger / Width: 2 / Precision: 3 / Scale: 0
SDE_CLOSEPOLY_ERR_FL / Data type: String / Width: 1 / Precision: 0 / Scale: 0
OBJECTID / Alias: OBJECTID / Data type: OID / Width: 4 / Precision: 0 / Scale: 0
SDE_POLY_PART_COUNT / Data type: SmallInteger / Width: 2 / Precision: 3 / Scale: 0
Shape / Data type: Geometry / Width: 0 / Precision: 0 / Scale: 0
SDE_MULTIPART_SHP_FL / Data type: String / Width: 1 / Precision: 0 / Scale: 0
PITTARIB.POLYFEATURE_SDE.AREA / Data type: Double / Width: 8 / Precision: 38 / Scale: 8
SDE_INTERSECT_ERR_FL / Data type: String / Width: 1 / Precision: 0 / Scale: 0
PITTARIB.POLYFEATURE_SDE.LEN / Data type: Double / Width: 8 / Precision: 38 /Scale: 8
SHAPE / Data type: Geometry / Width: 4 / Precision: 0 / Scale: 0
SHAPE.AREA / Data type: Double / Width: 0 / Precision: 0 / Scale: 0
SHAPE.LEN / Data type: Double / Width: 0 / Precision: 0 / Scale: 0
Based on the format from the online help, I'm guessing the attribute file should be in this form:
<shpCol> [sdeCol] [type] [size] [nDecs] [NOT_NULL]
So, the SHP > SDE fields/info in the text file are as follows:
OBJECTID OBJECTID SE_INTEGER 4 0
OBJECT_ID_ OBJECT_ID_FK SE_INTEGER 8 0
SDE_FEATUR SDE_FEATURE_DATE SE_DATE 36 0
TEST_LINE_ TEST_LINE_PART_COUNT SE_INTEGER 2 0
TEST_POINT TEST_POINT_PART_COUNT SE_INTEGER 2 0
TEST_THREE TEST_THREE_POINT_COUNT SE_INTEGER 2 0
SDE_POLY_P SDE_POLY_PART_COUNT SE_INTEGER 2 -
AREA AREA SE_DOUBLE 27 15 -
LEN LEN SE_DOUBLE 27 15 -
Upon loading, the program returns a fatal error and I have to exit out.  Do I have this in the wrong format?  Should I use 'N' instead of SE_INTEGER, for example, as the load type?  Do I need to use the SDE Layer field information (width, decimals, etc) instead of what I got from the Shapefile?
VinceAngelo
Esri Esteemed Contributor
Do not attempt to load into the AREA and LEN shape properties. If you use 'sdetable -o describe'
you'll see the column layout that 'shp2sde' sees; this should help.
The types are all equivalent, so you only need 'shpname sdename' in the mapping file. Don't
mention the shape column in the mapping file (-l table,COLUMN handles that).
- V
BartPittari
- V
Vince,
That file change seemed to work in one of the environments I'm using (SDE 9.3.1)
but when I run it in the other environment (SDE 9.2), I get this:
SDE Code (-53): Invalid column data type
Line  1: Error in parsing ColDef string.
" "OBJECTID
        Error, reading column specification file
Not sure if it matters, but the 9.2 version is working off of Solaris and the 9.3.1 is working from Windows.
VinceAngelo
Do you have an escape character in the Unix mapping file? If it was edited on Windows
it may be missing a terminal newline (or have embedded CR before the LF).
- V
BartPittari
- V
That did it!! (thank you vi, lol) - UNIX didn't like the CR (^M as it looks in UNIX).
Thank you.  How do I mark this as solving the problem?  I'm still trying to get accustomed to the interface.
VinceAngelo
Yup, 'vi' is your friend.
They never got the marking capability running on the arcgis.com Forums.
- V
BartPittari
- V
Which explains why I didn't see it.  It was pretty visible on the old versions.  Do they just mark it as complete?
