.shp to autoCad (.dwg)
8979
09-06-2012 09:00 AM
jasonlewis2
How do I convert shapefiles to autocad or .dwg files using arc1o? Any andvice or help would be much appteciated.
Thanks Jason
TahirTamba1
Jason9558,
You can perform this task in 2 ways:
In ArcGIS 10 using ArcMap click on the Catalog docking panel and click on ToolBox / ConversionTools / To CAD /Export To CAD. In the Export toCAD Window, select your input shapefile feature and in the output Type, click on the Dropdown box and select DWG type format you want to export to and choose the location and the output DWG file name and at least click on the Ok button to run the conversion process.
You can perform the same process using ArcCatalog by activationg ArcToolBox from ArcCatalog GUI.
Hope that this help.
Regards
ttamba
jasonlewis2
Thank you very much very helpful!
DaniellePapineau
And you can do it directly from the Table of Contents.  Right click on your shapefile/layer, choose "Data>Export to CAD".  It's the same tool from the toolbox as was mentioned previously, just a quicker way to get it.
