shapefile to WASP roughness MAP file, dxf with attributes
2114
06-20-2012 05:41 AM
AnneKull1
Hello!
I need to convert polyline shapefile with roughness values (Left_rough, Right_rough) to WASP rougness map file. I have tried to use arcscript http://arcscripts.esri.com/details.asp?dbid=13950, but it does not work. SAGA GIS is suggested to use to convert shapefiles to WASP map values, but it only converts terrain values (only one elevation field). WASP also can import dxf files (dxf2004), but I can not generate dxf file with attribute values (Left_rough, Right_rough). I use ArcGIS 10.0 (ArcInfo). Can anybody suggest anything which could help me?
Thank you in advance,
Anne
