SDESETUP Says Oracle User does not have Privileges
2267
11-12-2012 12:34 PM
JeremyVanGelder
I am trying to setup a second SDE geodatabase in an Oracle database.  Stats are as follows:
Operating System: Windows 7 63 Bit
RAM: 16GB
Database:  Oracle 11g Express
ArcSDE 10.0
ArcGIS 10.0 ArcInfo
I've been following this help article:
http://webhelp.esri.com/arcgisserver/9.3/java/index.htm#geodatabases/using_-2001045921.htm
The Oracle database has an SDE geodatabase.  I have set up a new Oracle user with the appropriate privileges.  When I run sdesetup with the following parameters, it states that, "Current user does not have privilege to install geodatabase instance."
sdesetup -o install -d oracle11g -i 5151:development -u development
I have logged into Oracle with an admin account and successfully granted all of the privileges that the error asks for, and I have done so twice.  I have confirmed that the user has those privileges by checking Oracle's sqldeveloper gui program.  Is there something I have missed?
VinceAngelo
Esri Esteemed Contributor
Did you grant the 'development' user all the permissions that the SDE user requires for initial setup?
I generally just grant DBA for long enough to install or upgrade, but the documentation is quite clear
on what is required.  Ironically, the user-schema geodatabase user requires *more* permissions than
SDE after install, since the SDE user shouldn't ever own spatial data.
I realize the the documentation says that user-schema geodatabases are a great way to have dev,
test, and production data in one instance, but that is as about as wrong as the documentation gets --
you don't get the benefit of isolation, and you can't limit the impact on production, and the naming
must be different between "instances".  In reality, only separate instances give the isolation that most
shops require to distinguish between dev and production, so I urge you to be careful on how you
utilize user-schema geodatabases.
- V
VinceAngelo
- V
JeremyVanGelder
Granting DBA to the user worked.  Thanks for the warning about development/production environments.  I will keep that in mind.
