sdemon command line: cannot connect to database
2917
03-14-2014 05:45 AM
gp2014
Dear all,
I have installed on a Client with SO VISTA:
- ArcSDE 10.1 Command lines +SP1.
- ArcGIS Desktop 10.1 + sp1 +qi.
- oracle instant client:  instantclient-basiclite-win32-11.2.0.1.0
On a Linux server I have an enterprice geodatabase (direct connection architecture) on linux/oracle11gr2
Now, when I execute sdemon by cmd:
sdemon -o status -i sde:oracle:<ipserver>/<sidname> -s<ipserver> -usde
the following error appear:
Cannot connect to database because the database client software failed to load.
Be sure the database client software is installed and configured correctly., Un
able to get instance configuration
Why?
If I connection ArcMAP to Oracle with the some parameter the connection work fine.
Regards
VinceAngelo
Esri Esteemed Contributor
All ArcSDE command-line utilities are 64-bit.  You must have a 64-bit database client
for them to work with Direct Connect.
- V
