SDE log file
2740
5
06-23-2014 03:47 AM
SyedMasood_Khadri
hi
The log file tables (SDE_LOGFILES, SDE_LOGFILE_DATA) are not populated in the case of selection (more than 100 records) made using ArcGIS.
MichaelVolz
Esteemed Contributor
I believe that is when SDE log files are populated.
George_Thompson
Esri Notable Contributor
What type of log files is your instance set up to use?
http://resources.arcgis.com/en/help/main/10.2/#/Log_file_table_configuration_options_for_geodatabase...
-George
--- George T.
SyedMasood_Khadri
hi, thanks
I am using default tables (i think default is shared log files).
The user has suitable privileges as mentioned in the link.
Do i need to configure dbtune parameters related to shared log files for DEFAULT keyword ??
jayasudha
hi,
There are some parameters set with keyword LOGFILE_DEFAULTS.
Do i need to set the same parameters for DEFAULTS keyword to populate SDE_LOGFILES, SDE_LOGFILE_DATA tables ??
regards
VinceAngelo
Esri Esteemed Contributor
No. Only the LOGFILE_DEFAULTS keys are used.
- V
