SDE lock problem
8310
03-13-2012 03:55 PM
DonFreeman
I need to make some structural changes to a feature set I created recently in a SDE geodatabase,  but I cannot because it is locked. I can find no reason why it should be locked. Is there a way to determine who/what has the lock on it so I can clear it?
Thanks
JakeSkinner
Esri Esteemed Contributor
Hi Don,
There a few tables that you can check to see if there are any locks placed on a feature class.  These are:
sde.SDE_state_locks
sde.SDE_object_locks
sde.SDE_layer_locks
sde.SDE_table_locks
I would first check with the sde.SDE_table_locks table to see if there is a lock there.  You can run the following query first:
select registration_id from sde.SDE_table_registry where table_name = 'AIRPORTS'
Replace 'AIRPORTS' with the feature class name.  Take the returned value (i.e. 235) from this query and then execute:
select sde_id from sde.SDE_table_locks where registration_id = 235
You can then check the other tables with the value returned (i.e. 5256) from this query to see if there are any additional locks.  Ex:
select * from sde.SDE_state_locks where sde_id = 5256
select * from sde.SDE_object_locks where sde_id = 5256
select * from sde.SDE_layer_locks where sde_id = 5256
You can determine the user that is creating the lock(s) by querying the sde.SDE_process_information table.  Ex:
select * from sde.SDE_process_information where sde_id = 5256
DonFreeman
Thank you! I will give those a try. Turns out the locking user was me. Don't know why but even though I had removed all the layers from my project ArcMap was still maintaining locks on the feature classes. After I shut it down and restarted everything was fine. Go figure.
JakeSkinner
No problem.  Esri has actually made identifying locks much easier at 10.1.  This can be accomplished right from the Catalog window.  You can simply right-click on the geodatabase and you are presented with an Administration option.  Here there is a tab showing which locks exist and which user is placing the lock.
