sde- file transfer with relationship
1675
09-10-2012 03:18 PM
RudyCharlot
I posted the question below last week, concerning sde database file transfer with relationship.
The answer I got was "You can simply perform a copy/paste of the feature class/table in the catalog window and the relationship class and the associated feature class/table will copy along with it". I tried that it did not work for me or unless something is causing it not to work. If someone can help me with a different method I would really appreciate it. Thank you very much.
How do I transfer files with relationship to ArcSDE database? or do I need to rebuild the relationship after the file has been transferred? I am currently using ArcGIS 10.0
JakeSkinner
Esri Esteemed Contributor
Hi Rudy,
After your right-click on your feature class that has a relationship class, and then you right-click on the geodatabase to paste the data into, you should receive a dialog similar to the following:
[ATTACH=CONFIG]17595[/ATTACH]
You can see that by copying/pasting the feature class will also copy the relationship class, the other table/feature class participating within the relationship class, and any domains.
What do you receive after you right-click > Paste?
RudyCharlot
Hi Rudy,
Thank you very much for your help. The transfer process worked well. Kudos to you.
Sincerely,
Rudy Charlot
