sde commands
2555
02-21-2018 07:43 PM
jayasudha
we are using arcgis 10.1, oracle 11g database and using direct connection, there is no service.
the commands (sdeconfig, sdedbtune, sdelog, sdemon) works fine for me.
the commands (sdegdbrepair, sdesetup) does not work and gives error.
sdegdbrepair -o diagnose_metadata -d ORACLE11G -u sde -p xyz -i sde:oracle11g:orcl3
ESRI ArcSDE Server Repair Utility Thu Feb 22 09:11:47 2018
Error: Underlying DBMS error (-51).
Error: Unable to list inconsistent metadata.
Asrujit_SenGupta
Well....it's been a long time working with SDE Command line tools...
This seems to point to an issue in connecting to the Database.
Maybe try something like below:
sdegdbrepair -o diagnose_metadata -d ORACLE11G -u sde -p xyz@orcl3
sdegdbrepair -o diagnose_metadata -d ORACLE11G -u sde -p xyz -i orcl3
In case you have 10.3.x or higher Desktop available, check this: Diagnose Version Metadata—Help | ArcGIS for Desktop
Asrujit_SenGupta
jayasudha
Asrujit_SenGupta
If possible, do share what worked for you...so that it may help others for reference..
jayasudha
both options
