Saving table edits in ArcGIS Pro ModelBuilder
1588
05-23-2019 09:04 AM
ForrestFollett1
I have a model that is using a raster iterator to run through a folder of rasters, perform an operation on them, then join the resultant info to the attribute table of a shapefile I have.  I can't get past the first iteration because it says the table is not editable when trying to perform the join in the second iteration.  I'm assuming this is because the edits from the previous join have not been saved.  Is there a way to perform these joins outside of edit mode or add a step in the model to save the edits before iterating?
PeteVitt
I'm having a very similar issue.  I delete some features from a feature class in model builder, then try to do an append in the next step, and I'm getting an error saying the feature class is read-only
