Sample doesn't work anymore...
868
03-05-2012 01:22 PM
TaylerHamilton
So, for some reason the sample tool won't work for me anymore. I have used it in the past without any problems, so I have no idea why it suddenly decided to stop working.
Anyways, I need to extract the values from 2 different rasters so I can put them into SPSS and analyze the rasters.
I wanted to use the sample tool to extract the values with the geographic coordinates so I can re-add them later to arcmap with new values calculated outside of arcmap.
But, my sample tool isn't working.
Does anyone know how I can do this using different tools? Or has anyone had this same issue with sample and know how to fix it?
Thank you!!
TimothyHales
Esri Notable Contributor
If you have Geostatistical Analyst then you can use the Extract Values to Table tool.  If you have a points layer then you can use the Extract Value to Points or Extract Multi Values to Points.
