Running Spatial ETL Tool in Python Script
3578
01-19-2011 11:00 AM
deleted-user-rmQdIupSdOqe
How do I run a Spatial ETL Tool I built in an ArcCatalog toolbox in a python script?
General method for other tools is to import the toolbox.
Then:
arcpy.MyTool()
Spatial ETL tools are not showing up as part of the module.
Created a model, embedding the spatial ETL tool within it. Could call this tool in the arcpy module, but it will not run in PythonWin.
Message:
  File "C:\Python26\Lib\site-packages\Pythonwin\pywin\framework\scriptutils.py", line 312, in RunScript
    exec codeObject in __main__.__dict__
  File "C:\ESRI Toolboxes and Python Scripts\Scripts\DumptoMISteps\Step3.py", line 111, in <module>
    arcpy.AWTOOLS.Step5FMETool()
  File "U:\GIS Department\ESRI Related\ESRI Toolboxes\My Toolboxes\RFP TOOLS ANN WAGNER.tbx", line 218, in Step5FMETool
    #! FME_TYPE="fme_char(width)"
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000816: The tool is not valid.
Failed to execute (Step5FMETool).
From ArcCatalog, the tool runs fine.
Suggestions?
BruceHarold
Esri Frequent Contributor
Hi
Scripts running out of process in ArcGIS that call the Data Interoperability extension must check the extension out:
arcpy.CheckOutExtension('DataInteroperability')
Regards
