Read domain code and value from sde 10 by oracle 10g
1293
01-05-2013 06:17 AM
AmmarAssem1
I have sde 10 in oracle 10g and i need query that I can select code and value .
Best regards
ForrestJones
Hi Ammar,
Is this what you are looking for?
Example: Resolving domain codes to description values using SQL/
Remember to configure the extproc too if you are going to use the above method to query the xml in the gdb_ tables in oracle:
Configuring the Oracle listener to access the geodatabase with SQL
