Reverse Geocoding - only need Country
1575
01-09-2013 10:37 AM
SallyVegso
Hi-
I have a list of several thousand latitude/longitude points from all over the world. I need to reverse geocode them and all I need is the country. I just want to know what country the point lands in. Most of them will be in wild uninhabited areas with no real address nearby.  I have tried using the Reverse Geocoding tool with no luck. I use the ESRI_ PLACES_WORLD.geocodeserver and I get an output data set with a blank field called PlaceName. I am using ArcGIS 10. I was hoping that I could select an option to just get the Country name or code out, but the only option I see is Address.
Any ideas or advice would be helpful.  I know there are webservices that could do this but I don't know how to batch use them and I don't use mySQL etc.
thanks-
Sally
BradNiemand
I think you would be better off using a spatial join or intersect using the World Countries polygon layer from ArcGIS.com.
Brad
