Resolution Change
4596
01-04-2015 09:53 PM
Juvinlanger
Hi All,
I downloaded a  soil moisture data from NLDAS which has a resolution of 0.125 degree. It is in ASCII format that i opened in excel later on. I need to change this 0.125 degree resoultion into 1000 meters, how do i do it? Is it possible to do in excel?How? i appreciate your help. Thanks
Juvin
DanPatterson_Retired
Assuming that you can load it as a layer in ArcMap, you need to project the data from its current format which is in decimal degrees to some projected coordinate system (eg. UTM etc etc), using a cell size of 1000m.  Once it is in the appropriate format, then you can export to ascii
