Renaming a projection definition
961
03-13-2013 05:48 AM
MikeRadko
We use a custom projection for our geodatabase and it has always been named "NAD_1983_Transverse_Mercator".  I would like to change the name of the projection to something less generic that captures the name of our company in the title, for example "Idaho_Power_Transverse_Mercator".  The projection parameters remain the same, just the title would change.  I've tried using the Define Projection tool but it fails to write over any existing projection parameters. Can I remove a projection definition in a geodatabase and then run the Define Projection tool to reassign the parameters?  Any other suggestions?
Mike
