Rename Feature Classes Based on Polygon Index Attributes
2387
04-05-2023 10:20 AM
ChadR
I have a file gdb containing the following items, and I am using version 10.8.2
200 line feature classes currently named Contour_Tile1, Contour_Tile2, etc...
I also have a single polygon feature class named Index_5000ft.  It contains 200 polygons (one bounding polygon for each of the previously mentioned line feature classes).  In the polygon attribute table there is a column named [Tile_Num] and it contains values like GAW_30310026.  There is no correlation between the name of the line feature class, and the polygon that it might fall within.  For example, all the lines in the Contour_Tile1 FC, might fall inside an index polygon with the attribute of GAW_30310026.  The only thing they have in common is their spatial relationship (extent).
Lines contained within any one of the line feature classes, will always fall completely within a single polygon found in the Index_5000ft FC.  Lines from a single FC will never intersect with more than one index polygon.
What I want to do is rename each of the line feature classes from Contour_Tile1, to something like GAW_30310026, which is found in the [Tile_Num] column of the corresponding polygon attribute table.
FYI: Right now I'm only having to deal with 200 tiles, but I will need to repeat this process many more times, so "automation" is the only way I can make this work.  In other words, I can't resort to manual renaming because I will have many thousands of FCs to deal with.  Does anyone have any ideas on how to rename the line FCs, as described here?
DavidPike
MVP Notable Contributor
Obviously try it on a copy and/or subset of your data first (and keep a backup of the original for some time regardless)  also close down arcmap etc to get rid of any locks for renaming:
import arcpy
import os
index_fc = r'C:\ArcGIS\yourFGDBgdb\Your index polygons'
line_gdb = r'C:\ArcGIS\FGDB containing your lines.gdb'
#list the fc names and paths to line FCs
arcpy.env.workspace = line_gdb
lines_fclist = [[fc, os.path.join(line_gdb, fc)] for fc in arcpy.ListFeatureClasses(feature_type="line")]
#create a list to store FC name and
#single line geom from each lines FC
linefc_list=[]
for line_fc in lines_fclist:
    with arcpy.da.SearchCursor(line_fc[1],["SHAPE@"]) as cursor:
        for row in cursor:
            linefc_list.append([line_fc[0],row[0]])
            break
#create a dictionary of line fc path and intersecting index polygon name
index_line_dict = {}
with arcpy.da.SearchCursor(index_fc,[“Tile_Num","SHAPE@"]) as cursor:
    for row in cursor:
        for line in linefc_list:
            if row[1].disjoint(line[1]) is False:
                index_line_dict[os.path.join(line_gdb, line[0])] = row[0]
                break
print(index_line_dict)
#rename lines to match
for filepath in index_line_dict:
    arcpy.management.Rename(filepath,index_line_dict[filepath],"FeatureClass")
DavidPike
Are the lines in their own FGDB separate from the index polygon, what's the layout of the data - is there anhything else in that FGDB?  If you iterated through that workspace it would only return the line FCs?
ChadR
Right now the 200 line FCs and the one Index polygon FC are in the same FGDB, but I can easily move the index polygon FC to its on FGDB, so an iterator would only see the line FCs.
DavidPike
import arcpy
import os
linefc_list=[]
        for row in cursor:
            break
    for row in cursor:
                break
ChadR
I will give this a shot tomorrow and let you know how it goes.  Thank you very much for responding!
ChadR
David - that did the trick.  You're awesome!
