Raster Projection Removal
14197
6
11-06-2010 09:55 AM
HayleyP
Is it possible to remove a projection from a raster? I would like to georeference my raster, and cannot do so with a set projection.
RobertBerger
Greetings,
Yes, you can remove the projection from a raster: Open the dataset properties in ArcCatalog > Edit Spatial Reference > Remove.
Robert
ranaahmad
please can you help me ? i have the same problem i want to remove project raster in arcgis 10.1
i send image which does not match with projection raster
BenLeslie1
I cannot see this option in 10.2 - is it possible to remove the spatial reference in 10.2?
NeilAyres
Ben, my version is 10.3.1, but I am pretty sure it's the same in 10.2...
Right click on the dataset in Catalog. Scoot down to the Spatial Reference part, click edit to bring up the spatial reference properties page.
Click the little pull-down next to the world icon at the top. Click Clear.
BenLeslie1
Ah ha - it is the same, thank you.
NeilAyres
And, in the case of external files like tiff or jpeg, you may have to use the normal win file explorer to delete any associated files like worldfiles - tfw, and any aux or xml.
