raster processing, tiling
3448
5
07-07-2011 02:36 PM
ericcgrey
I have one big mosaic and many polygons(shapefile), each polygon is a rectangle 1000 by 1000m however there is an ovelap between them 100m.
How to create a raster for each polygon from my shapefile?
I have tested "split raster" but it doeasn't solve the problem
EricRice
Esri Alum
Eric,
Split Raster is a viable tool but you would have to fill out the parameters so the output rasters aligned with your polygon records. If you prefer not to use this tool, you can make a very simple model using the Clip tool.  In the model, add an iterator for Feature Selection.  The iterator will loop through each polygon record and use its geometry to clip the raster.
Attached is a graphic of the model to do this.  Here are examples of using iterators in ModelBuilder .
Note, Iterators are only available in ArcGIS 10.0.
Regards,
Eric
ericcgrey
Thank you for the answer, however output rasters will overwrite each other. I get only the last clipped raster!
I would like to assign the ID value from selected polygon (from my shapefile) to raster name (see the file attached: Value2 -> test)?
Is it possible?
MarkChilcott
Hi Eric,
Have you tried this method on real data?  I can't get it to work.
The clip values don't keep iterating and changing with the new tiles, and I can't see a way to change the name of the output raster file - so any output is over written each time.
What am I missing here?
Cheers,
mark
MarkChilcott
I see my error now.  Read the manual and use in-line variables as the output.
Cheers,
Mark
NoahHuntington
Thamks for this.  Adding in line variable worked liked a charm!
