Raster name in the Geodatabase
1509
01-20-2014 10:09 AM
CatherineMichaud
In Arc Gis (Arc catalog), I created a geodatabase. I then imported raster, but their original names have been changed.
Name example as input:
NSS.HRPT.NK.D13172.S1035.E1048.B7854545.WI
Result: Name example output(in geodatabase):
NSS_1
NSS_2
How to keep the full name? (NSS.HRPT.NK.D13172.S1035.E1048.B7854545.WI)
I accept the explanations using model builder or Python.
Thanks in advance,
Catherine
NidhinKarthikeyan
Honored Contributor
The original name of the raster contains invalid character (.)
While importing the raster, you can name it as NSS_HRPT_NK_D13172_S1035_E1048_B7854545_WI
NeilAyres
If you're looping through your rasters to be imported, you could change the name using python's "replace" like :
InRas = "NSS.HRPT.NK.D13172.S1035.E1048.B7854545.WI"
OutRas = InRas.replace(".","_")
print OutRas
Cheers,
N
CatherineMichaud
Thanks you for the quick reply
