Raster Dataset quality compared to Mosaic Dataset
917
11-23-2011 02:28 AM
MarkusHoffmann
If I load a 1Bit Raster to a Mosaic Dataset (8Bit) the result looks totally different to a Rasterdatset which is loaded to Raster Dataset with the Option �??Convert 1 Bit data to 8 Bit�?�. The Mosaic Dataset just looks like the original Image. Is there a special stretch or something else which is usesd when I check �??Convert 1 Bit data to 8 Bit�?�? Does anyone know the workflow to get the same result in a Mosaic Dataset.
Especially when I zoom to scales which use the Overviews the result of the Raster Dataset looks much better (Screenshots attached)
I tried different interpolation and compression, stretch algorithms with no comparable result.
Is there an official workflow to load 1 Bit Raster to a Mosaic Dataset?
Thank you in advance,
Best,
Markus
PS: attached a comparison image
