Raster data disappears when georeferencing and I turn on auto adjust
2453
08-03-2013 02:32 PM
TiffanySprague
I'm trying to georeference a tif file (no spatial data but showing township-range-sections) against a NAD 83 t-r-s map I have for the same area. Everything is fine until I turn on auto adjust. If I turn it on before selecting control points, my tif image disappears at the 2nd control point. If I first establish some control points (say 2 - 4) and then turn on auto adjust, the tif image then disappears (even when my RMS error is shown as very low).
Any ideas/suggestions? I don't know if this is a problem with what I'm doing or a corrupted file issue.
Dan
TiffanySprague
More info: it appears that when I turn on auto adjust, the raster image shifts wildly. If I zoom to the raster layer it reappears but nowhere near the reference map. It's as though the control points are being wildly misread, even though the RMS displayed after turning on auto adjust aren't bad.
I'd appreciate any ideas.
Dan
JeffreySwain
Consider the coordinate systems you have in the map document. Ideally, you should have one reference raster in the coordinate system you are trying to put the unreferenced file.  Any combination of multiple coordinate systems or particularly if the data frame and the target coordinate system are wildly different.
JordanHale
Are you placing all of your initial control points along the same "vector"? In other words, could you connect them with a single straight line? If you are, try placing your first points according to locations on the raster map that a) are as far away from each other as possible and b) are not in a straight line.
JordanHale
Sorry, I just saw this post, it looks like others are having the same issue...
