Raster Catalog Bleaches Raster Datasets
1753
03-27-2013 07:51 AM
BenWagner
I'm trying to load several .sid files into a Raster Catalog, which I can do without issue. However, when I bring that Raster Catalog into ArcMap all of the imagery is bleached out. I didn't see any settings for color display while creating the Catalog. I set the Catalog up as unmanaged. The .sid files display properly when brought into ArcMap individually. I have included an attached image showing a comparison between a single .sid and the Raster Catalog. Any thoughts or suggestions on how to get the Catalog to display properly?
Thanks!
PrasantaBhattarai
Greetings!
You might have the raster catalog displayed with a stretch applied to it. For your raster catalog, please check the Layer Properties > Symbology > Stretch Type and set it as "None" (or same as what you have for your SID).
Hope this helps.
Regards,
Prasanta.
PrasantaBhattarai
Greetings!
Hope this helps.
Regards,
Prasanta.
BenWagner
That did it! Thanks, Prasanta!  🙂
