Querying point X,Y data stored in a database
2901
11
09-18-2012 11:36 AM
GagagDa_Morvi
Due to some reasons, I am required to store X,Y point data in a database (and not convert them to point features). The X,Y data represents points in a UTM projection. I need to search for a point that is nearest to a given point in a query. The given point is also in the same UTM projection. Is there an efficient way of accomplishing this using SQL query? Thanks!
AnthonyGiles
Honored Contributor
Gagag,
Not tested but you will need to do some pythagoras to work out the distance, ie:
SELECT sqrt(pow(inputxvalue - fieldx,2) +(pow(inputyvalue - fieldy,2)) AS Distance FROM tablename ORDER BY Distance LIMIT 1
Regards
Anthony
GagagDa_Morvi
Thansk, anthony. This query involves full table scan (I think). Is there a way to avoid that?
AnthonyGiles
Honored Contributor
Gagag,
Not that I know of, but I am not by any means a SQL expert, maybe there is someone else that may know better
Regards
Anthony
VinceAngelo
Esri Esteemed Contributor
In software engineering terms, the "big O notation" of a query on the closest distance from any
single point is inherently "O(N)" [the effort required to solve the problem is proprtional to the
number of rows in the table -- aka, full table scan].
The only to way to reduce processing is to put a limit on the magnitude of the distance by
indexing both X and Y ("CREATE INDEX foo ON table(xcol,ycol)") and adding a WHERE
clause to the query:
WHERE xcol between (inputx - theshold) and (inputx + theshold)
  AND ycol between (inputy - theshold) and (inputy + theshold)
This is, in essence, what you're losing by not being able to generate a buffer about the search
point and use the spatial index to limit return results [an unbounded query on a spatial relationship
of distance(inputpt,ptcol) would also be O(N)].
- V
GagagDa_Morvi
- V
Thanks! I do have the index as you have suggested - I will try out the where clause and see how it goes.
VinceAngelo
The index won't do any good without a where clause constraint to exploit it
(in fact, it would just slow down INSERT performance).
- V
BruceHarold
Esri Frequent Contributor
Hi
If you have the freedom to alter the schema of your table you could implement a geohash-based query:
http://code.google.com/p/python-geohash/
You would need to calculate a hash onto each point, with a precision to suit your data.
Then your nearby query would devolve into a string range query.
Regards
BruceHarold
See the attached functions; requires ArcGIS 10.1
Regards
GagagDa_Morvi
Hi
Regards
Very interesting approach. Will try. Thanks!
