Quality of raster data
4083
06-15-2016 02:08 AM
AnzhelikaKamza3
Hello,
I have ArcGIS 10.3.1 version. My colleaques provide me GeoTIFF. But when I open this raster in ArcMap or ArcCatalog I can see pure quality of raster data. But in QGIS or in Photoshop etc, quality is more better?
Could you please advise with this issue&
Look forward,
Regards,
Anzhelika
P/ S
In attached file you can find screenshots of this data.SSS_QGIS.pngSSS_ArcGIS.png
AnzhelikaKamza3
Dan,
We found soluthion!!!!
In ArcMap Option window should set properties for raster.
DanPatterson_Retired
build pyramids and statistics
AnzhelikaKamza3
Hello Dan,
thanks for your replay.
After statistic calculation raster doesn't changed, still bad quality.
In ArcMap I changed Strech type from Percent Clip to Custom and after that qualiy more better. For saving this properties I used Data Export-and fill Use Renderer, No Data as 256. Result is black square without raster. If I put No data as 0 - there is no raster.
In ArcGIS 10.0 we just used Use Rendered and finaly it was raster with good quality. Why 10.3.1 don't save properties?
regards,
Anzhelika
AnzhelikaKamza3
Dan,
