Product of AutoDesk?
1613
11-03-2013 11:46 AM
Ryan_Galbraith
Of all the people that use GIS/CAD data, which product of AutoDesk do you use?
AutoCad
AutoCAD LT
AutoCAD Civil
AutoCad Map
Other:
V_StuartFoote
MVP Alum
Ryan,
We load AutoDesk Map3D and Civil3D for any geospatial work as they handle projected coordinate systems.
But, you can work with XREF data in State plane or UTM projection to reposition drawings from any of the AutoDesk AutoCAD products.
Stuart
by Anonymous User
Not applicable
Original User: rdg129
That is very interesting - I wasn't aware that you could load both!  Any particular method of doing this?
V_StuartFoote
MVP Alum
Ryan,
Actually, should have said we'll load either depending on the primary use in the lab--but Map3D with Raster Design for any GIS work and Civil3D in the Engineering labs.
Stuart
by Anonymous User
Not applicable
Again - thanks for the info - still just a newbie at AutoCAD and the product instalations seem just as confusing as ArcGIS suites.
