Problem with Raster Calculator/burning streams
2732
12-26-2013 12:48 PM
by Anonymous User
Not applicable
Original User: dewey32167
Hello All,
I hope this will be a simple question.
I have a DEM that i am trying to burn streams into except that my streams are road side ditches.
I have converted the polylines into to a raster and i am trying to to burn them in using raster calculator but when i minus the difference between the two the only thing that comes back is the ditch. See pictures attached [ATTACH=CONFIG]30123[/ATTACH][ATTACH=CONFIG]30124[/ATTACH]
Any idea for a quick fix?
Thank you ahead of time
Additional note: I know about arc hydro tool set but it converts my DEM to meters which wouldn't be a problem except we have 70+ DEM to work with and are trying to automate this processes as much as possible
DanPatterson_Retired
I suspect non-ditch areas are classed as nodata.  reclass that area to 0, then do the subtraction, otherwise you will end up with just the ditches
by Anonymous User
Not applicable
Thank you so much!
I ended up taking this one step further and Did a ISnull Function Then A Con Function to combine the DEMS.
For anyone interested i simply Did Isnull to my Ditches then did:
[ATTACH=CONFIG]30126[/ATTACH]
Null is the ISnull Raster
DEM_q29... is the background DEM
Ditch is the New Ditch that has been converted from a polyline to a Raster
