Problem with joining with a SQL Server data source. .DBF file works fine though?
1612
6
04-04-2012 02:14 PM
DustinReagan
I'm using ArcMap 10.0.
I'm trying to inner join (with the join tool) a shape file with a table from an SQL Server data connection.  It fails with 0 records.  Howerver, when I export the table to a .DBF file, then do the same join, it works as expected!?
Any ideas?  The data appears unchanged before and after the export.  It's something under the hood, I expect...
Dustin
JakeSkinner
Esri Esteemed Contributor
What are the field types for the shapefile and for the SQL Server table that the join is based off of?
DustinReagan
On the shapefile, the field is of type TEXT, on the SQL Server table, the field is of type nvarchar(154)
KenCarrier
Before doing the join click the validate join button in the bottom right of the screen, it could be you are using a reserved word or there are invalid characters in one of your field names in one or both of the tables.
Running the validate should give you a better idea of what is going on.
DustinReagan
Sorry, I should have mentioned that I tried the "verify" functionality, and it gave no warnings or errors.
DustinReagan
bump. still having this inexplicable problem.
JakeSkinner
Try importing your shapefile into a File Geodatabase and see if you experience the same behavior.
