Problem with Intersections in two Locators built on the same street centerline
736
12-15-2011 05:15 AM
CathyStanley
This was originally posted under a different Forum, but I did not have any luck getting a response.
I am in charge of the GIS data for our 9-1-1 Center. We have a very large street centerline and I have taken on the task of cleaning up the data and making it more functional for our Center and Emergency Responders. One of the additions I have made to our data is the use of Exit Ramps for our Interstates. I've added in block ranges for the Interstate to flow along with our Mile Markers. I have also added small ranges for the Exits. Our current centerline contains a single street name field and parsed fields. The Mapping used in our Center's software relies on the parsed fields for geoverification. When I use the Locator built using the single street name field, my intersections with Interstate / Exit works fine. However, when I use the Locator built using the parsed street fields, the same intersections will not verify. I have already run a TRIM command with all of the fields to remove any leading / trailing spaces. Everything looks exactly the same. Can anyone explain why the Locator using the parsed fields will not verify these intersections?
JoeBorgione
Could you post up the full, unparsed street names as well as the feild names and values of them parsed?  I'd be happy to take a look it.
