problem with Database Properties window
906
09-21-2010 05:04 AM
PatMadsen
When I open my Geodatabase Properties, the contents (General & Domain tabs) are not centered in the window and are, instead, offset towards the bottom-right corner of the properties window so I cannot view all of the items. Does anyone know why this is suddenly happening? This happens for all of my Geodatabases, by the way. Thanks!
MelitaKennedy
Esri Notable Contributor
Please check out my post in this thread:
http://forums.arcgis.com/threads/12258-Data-Frame-Properties-Box-Messed-Up-Arc10?p=36832#post36832
Hopefully, there's something in the links that will help you.
Melita
PatMadsen
Thanks for the reply! I tried to look up this problem in old postings but couln't find it - I guess I used the wrong tags.
Again, thanks!
