Problem with changing a set of symbols
626
07-02-2014 06:48 AM
DiederikJansen
Hello Everybody,
Just new here and I hope someone can help me out. Here is the problem:
I have a layer file that contains thousands of different elements numbered from 1 to around 20.000. I changed the symbol of around 200 of these elements by hand. All symbols are black but these 200 symbols are red and they are thicker (thickness = 10).
Now I want to change the color from red to orange and the thickness from 10 to 5. So basically I want to tell arcgis "if you see an element that is red and has thickness 10 change it to orange and thickness 5".
Is there any way I can do this?? Preferably without a script 🙂 for instance, I tried to order all symbols by symbolstyle, so I can select the red ones all at once, but arcgis doesn't seem to be able to do this.
Really hope you guys can help me out!
Thanks in advance!
Greetings
Diederik
