Problem using Quick Export in model builder
1869
04-17-2012 11:34 PM
ChrisMicallef
I am trying to build a model that will automate the export of a number of layers from our geodatabase to another format and I'm having a problem setting the output dataset for Quick Export tool in a model. I am using ArcGIS Desktop v10 sp4, and have a licenced copy of Data Interoperability extension - and it is active. The problem I am having is that I am unable to set the output dataset for the quick export tool in the model.
Outside of a model, I am able to set the output dataset for the Quick Export tool when run manually without any problems. However when the Quick Export tool is opened from within a model, nothing happens when I click the output dataset browse button?? I'm able to set the input layers without a problem, but not the output dataset.
[LEFT]I have also tried the Quick Import tool in a model, and the input dataset browse button works fine.
This behaviour is the same in both ArcMap and ArcCatalog, and whether I have the data interoperability extension active or not.
Am I  missing something or setting something wrong?
[/LEFT]
JamesDally
Hi Chris,
Did you get a solution to this? I've just encountered the same problem myself.
James
ChrisMicallef
No solution James. I think I'll report it as a bug.
MalcolmParnell2
FWIW, I have the same problem.
RobertJones2
In case google leads anyone else to this page hoping for a resolution, it's your lucky day! Fixed in a service pack:
http://support.esri.com/en/downloads/patches-servicepacks/view/productid/83/metaid/1721
Data Interoperability Extension 10 Service Pack 1
