Problem on Converting GDB Polygons to DGN
1511
08-28-2023 01:16 AM
MatsHardy
I have a gdb hatch-style polygon class A and I am trying to convert A to dgn polygons. I have appended the fields "Layer", "CadType", "Color", "Linetype", "LineWt" to A and set to "AMFM2_B_DR_EXT", "Polygon", 42, "Varies Across", "Varies Across" respectively. Then I run the ExportCAD conversion tool but the converted dgn is just empty polygons rather than hatched. Anyone have ideas?
Sample
Sample DGNSample DGN
OutputOutput DGNOutput DGN
Tags (4)
ChrisUnderwood
Hello @MatsHardy , did you add the extra CAD fields by using the Add CAD Fields tool ? Using that will ensure they all have the correct names & data types etc.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/conversion/add-cad-fields.htm
