PostgreSQL Question
5531
12
01-23-2019 01:08 PM
MarshallRobinson
Shot in the dark here. Does anyone know why I would be getting the following postgresql log error? I have an enterprise geodatabase loaded on postgresql on linux and I get this error even when doing a simple editing task for more than ten minutes or so. The feature class I create then get's corrupted and crashes arccatalog.
2019-01-23 13:34:02.425 MST [8901] LOG: execute sde_1548275642_3809_161: DECLARE sdecur_3809_161 BINARY CURSOR WITH HOLD FOR select V__68.shape , V__68.objectid from (SELECT /* ArcSDE NORMAL_FILTER */ b.objectid,b.shape FROM ugssde.sde.forfun b WHERE NOT EXISTS (SELECT * FROM ( SELECT SDE_DELETES_ROW_ID,SDE_STATE_ID FROM sde.d68, sde.sde_state_lineages l WHERE SDE_STATE_ID = 0 AND DELETED_AT = l.lineage_id AND l.lineage_name = $1 AND l.lineage_id <= $2 ) d WHERE b.objectid = d.SDE_DELETES_ROW_ID ) UNION ALL SELECT a.objectid,a.shape FROM sde.a68 a INNER JOIN sde.sde_state_lineages l ON a.SDE_STATE_ID = l.lineage_id WHERE NOT EXISTS (SELECT * FROM ( SELECT SDE_DELETES_ROW_ID,SDE_STATE_ID FROM sde.d68, sde.sde_state_lineages l WHERE DELETED_AT = l.lineage_id AND l.lineage_name = $3 AND l.lineage_id <= $4 ) d WHERE (a.objectid = d.SDE_DELETES_ROW_ID) AND (a.SDE_STATE_ID = d.SDE_STATE_ID) ) AND (l.lineage_name = $5 AND l.lineage_id <= $6) ) V__68 where ((V__68.shape && $7) = 't')
2019-01-23 13:34:02.425 MST [8901] DETAIL: parameters: $1 = '230', $2 = '255', $3 = '230', $4 = '255', $5 = '230', $6 = '255', $7 = '380000000500000008001000110F0000200000000000000092AAF9B6A4049DE28EAFB11482CCBF02000082CCBF02C2CCBF020000C2CCBF02'
2019-01-23 13:34:02.432 MST [30562] LOG: server process (PID 8901) was terminated by signal 11: Segmentation fault
2019-01-23 13:34:02.432 MST [30562] DETAIL: Failed process was running: DECLARE sdecur_3809_161 BINARY CURSOR WITH HOLD FOR select V__68.shape , V__68.objectid from (SELECT /* ArcSDE NORMAL_FILTER */ b.objectid,b.shape FROM ugssde.sde.forfun b WHERE NOT EXISTS (SELECT * FROM ( SELECT SDE_DELETES_ROW_ID,SDE_STATE_ID FROM sde.d68, sde.sde_state_lineages l WHERE SDE_STATE_ID = 0 AND DELETED_AT = l.lineage_id AND l.lineage_name = $1 AND l.lineage_id <= $2 ) d WHERE b.objectid = d.SDE_DELETES_ROW_ID ) UNION ALL SELECT a.objectid,a.shape FROM sde.a68 a INNER JOIN sde.sde_state_lineages l ON a.SDE_STATE_ID = l.lineage_id WHERE NOT EXISTS (SELECT * FROM ( SELECT SDE_DELETES_ROW_ID,SDE_STATE_ID FROM sde.d68, sde.sde_state_lineages l WHERE DELETED_AT = l.lineage_id AND l.lineage_name = $3 AND l.lineage_id <= $4 ) d WHERE (a.objectid = d.SDE_DELETES_ROW_ID) AND (a.SDE_STATE_ID = d.SDE_STATE_ID) ) AND (l.lineage_name = $5 AND l.lineage_id <= $6) ) V__68 where ((V__68.shape && $7) = 't')
2019-01-23 13:34:02.432 MST [30562] LOG: terminating any other active server processes
2019-01-23 13:34:02.433 MST [792] WARNING: terminating connection because of crash of another server process
2019-01-23 13:34:02.433 MST [792] DETAIL: The postmaster has commanded this server process to roll back the current transaction and exit, because another server process exited abnormally and possibly corrupted shared memory.
2019-01-23 13:34:02.433 MST [792] HINT: In a moment you should be able to reconnect to the database and repeat your command.
2019-01-23 13:34:02.433 MST [22353] WARNING: terminating connection because of crash of another server process
2019-01-23 13:34:02.433 MST [22353] DETAIL: The postmaster has commanded this server process to roll back the current transaction and exit, because another server process exited abnormally and possibly corrupted shared memory.
2019-01-23 13:34:02.433 MST [22353] HINT: In a moment you should be able to reconnect to the database and repeat your command.
2019-01-23 13:34:02.434 MST [790] WARNING: terminating connection because of crash of another server process
2019-01-23 13:34:02.434 MST [790] DETAIL: The postmaster has commanded this server process to roll back the current transaction and exit, because another server process exited abnormally and possibly corrupted shared memory.
2019-01-23 13:34:02.434 MST [790] HINT: In a moment you should be able to reconnect to the database and repeat your command.
2019-01-23 13:34:02.442 MST [30562] LOG: all server processes terminated; reinitializing
2019-01-23 13:34:02.457 MST [12107] LOG: database system was interrupted; last known up at 2019-01-23 13:32:21 MST
2019-01-23 13:34:02.495 MST [12107] LOG: database system was not properly shut down; automatic recovery in progress
2019-01-23 13:34:02.496 MST [12107] LOG: redo starts at 0/BD9C2368
2019-01-23 13:34:02.497 MST [12107] LOG: invalid record length at 0/BD9E0E78: wanted 24, got 0
2019-01-23 13:34:02.497 MST [12107] LOG: redo done at 0/BD9E0D50
2019-01-23 13:34:02.497 MST [12107] LOG: last completed transaction was at log time 2019-01-23 13:33:51.462835-07
2019-01-23 13:34:02.508 MST [30562] LOG: database system is ready to accept connections
MartinKrál
here is probably the official way how to solve it
ArcGIS (Desktop, Engine, Server) 10.6.1 PostgreSQL Performance and Version 10 Support Patch
Esri Support ArcMap 10.6 (10.6.1)
see:
BUG-000115897 - Polygon and Line Feature Classes imported into PostgreSQL 10.3+ using the Feature Class to Feature Class tool fail to draw and throw "Failure to access the DBMS server" error.
Regards
AndreasWalter
Hey,
thanks you for your answer! As I can see, the BUG-000115897 was fixed in the 10.7.1, so I guess I have to updgrade ...
Regards
MartinKrál
you can check that 10.6.1 PostgreSQL Performance and Version 10 Support Patch  first. That 10.6.1 patch solved our problem here too, so I think there is no need to upgrade.
Regards
