Polygon spatial data coordinates precision issue
1869
04-12-2021 12:20 AM
Srinivasraoboina
Polygon data is getting created from SDO object to ST geometry with 14 decimal precision as SDE featureclass and when export SDE feature class into A featureclass in FGDB, after 12 digits, numbers are getting added for 13th and 14th digits though 13th and 14 digits are 0's in SDE featureclass.
VenkataKondepati
Honored Contributor
This is expected floating-point behavior. Oracle ST_Geometry stores coordinates in double precision, and when exporting to a File Geodatabase ArcGIS writes out the full double value so extra digits may appear past the 12th decimal. It’s not data corruption. If you need fixed precision, round the coordinates on export (e.g., to 12 decimals) using Python/ArcPy or a geoprocessing workflow.
Regards,
Venkat
Follow me on: LinkedIn
If this response helps or is the solution to your post, please consider marking it as a solution
VenkataKondepati
Honored Contributor
Regards,
Venkat
