polygon cell mean calculation
908
06-06-2012 04:06 AM
ElaineKuo
System: ArcGIS 9.3
Dataset:
1. polygons of 3000 grid cells, each containing the average annual temperature of the grid cell
2. tree distribution map for 5 species (polygons) (species 1 to 5)
Purpose
I want to know the average annual temperature of the ranges of species 1 to 5.
Also, I want to compare if there is any difference in average annual temperature between the species distribution.
Procedure:
Step 1:
Clip the grid cell polygons using the distribution maps of the five tree species respectively.
Step 2: calculate the average of the annual temperature of the clipped polygons from species 1 to 5
Problem:
Please kindly advise which method in ArcGIS 9.3 can perform step 2 for polygons.
Thank you in advance.
(Once zonal statistics was suggested.
However, it was based on raster.
I tried it but found this was time and space-consuming
to transfer polygons to raster based on fine-scale.)
JimCousins
MVP Alum
Can you simply open the attribute table for each type, right click on the temp column, and choose statistics? This will return count, min, max, sum, mean, std deviation.
