Point to Raster
875
06-24-2014 03:01 AM
PhillippaSouthey
Hi, I am converting points to raster. I am using the Conversion tool, Point to Raster, and converting my points in batches. However, not all of my points are being converted e.g if I orginally had 7 points in a shapefile, only 3 are being displayed as raster cells after conversion. My cells size is the same for each conversion, and the cell size is set using a mask in the environments field.
Any thoughts on what steps I may be missing or what I should/should not be doing would be appreciated.
PhillippaSouthey
Ok, so my earlier problem seems to have something to do with the cell size being to large for some of the points. So what I have done is buffer the points, and then use the Polygon to Raster tool to convert. Again I set the cell size using a mask in the Environments field. However I get an Error 999999 Report when I try to run the conversion.
Any idea on what I am doing wrong would be appreciated.
