Point Feaure in SDO_GEOMETRY populating the SDO_POINT, instead of SDO_ORDINATES
3747
10
11-14-2012 04:01 AM
NicoleSchleifer
New to ESRI...
We have an existing Oracle 10g database with locator enabled and would like to be able to work in ESRI desktop and Server applications.
In ArcMap - Catalog 10.1
1 - right-clicked on table - Managed - Registered with GeoDatabase.
2 - Registered as Versioned
Set DBTUNE default to SDO_GEOMETRY
Added a new point in ArcMap, worked......... BUT...... it populated the SDO_POINT columns not the SDO_ORDINATES.
I feel that I've missed a step or a setting.
Looking for some suggestions and/or advice...
NicoleSchleifer
UPDATE:
Trying to do this outside the Esri environment was clunky and a bit messy.
An easier method inside the Esri environment that was just pointed out to me.....
In ArcCatalog: Rename the original table (Feature Class), then copy and paste it with the original name.
*This is for Stand-alone Features*
Way cool......... worked like a charm and maintains all the spatial metadata that Esri requires.
Super Impressed!
