Petrel File Format
10321
02-06-2012 08:39 PM
ArifKassim
Does ArcGIS support cgm format files? Or which format file can be used to import files created using Petrel Software?
TimHopper
Arif,
Unfortunately, ArcGIS does not support the viewing or conversion of cgm files.  Neither does the Data Interoperability Extension or Safe Software's FME product.
You'll need to use a third-party application, such as Larson's VisEx Professional, to convert the cgm to a tiff (the free VisEx viewer does not have the capability to convert between different formats).  The tiff can then be read or converted to vector format using tools within ArcGIS.
Although I haven't personally worked with Petrel myself, please take a look at the forum thread below which offers a few suggestions about this process.
ArcGIS to Schlumberger Petrel format
Hope this helps.
ChrisJepps
You could take a look at Exprodat's Data Assistant software:
www.exprodat.com/Software/TGDA/
This allows you to export and import various culture, interpretation, seismic and well data formats to and from ArcGIS, notably for Petrel, Landmark and KINGDOM.
Regards,
Chris
Vishalkumar
According to me this is not possible. ArcGIS will not support to a cgm file format.
