Personal SDE
15039
11
04-15-2010 01:28 PM
SteveMlinarich
I'm trying to get information on the Personal SDE. Could anyone direct me to some info on it?
Thanks!
dreamfool
About Personal ArcSDE (also called "Desktop Geodatabase" or "ArcSDE Personal Server" in some documents by ESRI):
I fully agree this is badly documented, but on the other hand, once you realize there is actually no real distinction between Personal, Workgroup, and Enterprise Geodatabases, except a licensing scheme determining the maximum no. of concurrent users for the geodatabase (Vince may protest here, but for the sake of this thread, I think it valid), it actually turns out to be surprisingly simple:
*** STEPS TO INSTALL "PERSONAL ARCSDE / DESKTOP GEODATABASE" ***
(E.g. with "ArcGIS for Home Use" license based on "ArcGIS for Desktop Advanced")
* EDIT: * It may be advisable to reboot in between / after some of these steps, e.g. installing SQL Server, so as to ensure all services are properly running and usable for the next step.
1) - Install SQL Server 2012 Expresss
I am not going to detail all steps of the SQL Server installation here, use the Microsoft documentation if in doubt. Basically, you can choose almost all defaults, as the 2012 version of SQL Server installation already sets it all up under restricted Windows accounts, so rather safe. The defaults will install "extra's" like the Reporting Services that aren't necessary for the functioning of an ESRI Geodatabase, so you may prefer to opt out on these "software developer / SDK options" of the installation.
NOTE: you can also use the ArcGIS for Desktop 10.2 installation to install SQL Server 2008 R2 Express, as it is included in the desktop installer, but since I guess you will want to use the "latest", install 2012.
2) - Create a new instance in the process of the installation of SQL Server. Record the name of the instance for later use.
3) - Ensure you are logged in as a full Windows Administrator on your PC.
This is very important, if you don't do this, the enabling of the database for geodatabase storage may fail. Make sure this administrative login is also registered with your SQL Server Express if you haven't already done so during the install of SQL Server Express (which is usually the case, so you can probably skip this).
4) - Start the ArcGIS for Desktop 10.2 installation.
NOTE: Yes, you need the installation for ArcGIS for Desktop, not ArcGIS for Server. So you can use the installation that is part of the 10.2 Desktop Advanced "ArcGIS for Home Use" program. It is downloadable from the Customer Care portal once you receive your license from ESRI.
5) - Once in the main screen, choose ArcSDE for Microsoft SQL Server 2008 R2 Express as the installation option.
NOTE: don't worry: it won't automatically overwrite or re-install your SQL Server 2012 Express, see next steps.
6) - Once the install wizard appears, choose Next
7) - In the next dialog that appears (Installation Options), deactivate the Microsoft SQL Server Express Edition option, since you already installed it in step 1). Leave the Enable geodatabase storage on SQL Server Express checked. You want your database to be enabled to use ESRI Geodatabases.
😎 - Click Next
9) - In the Choose a SQL Server Instance and add a Windows login dialog, choose under SQL Server instance name your instance created in step 1), e.g. YOUR_COMPUTER_NAME\YOUR_INSTANCE. Add a valid Windows Login who will administer the geodatabase, e.g. YOUR_COMPUTER_NAME\YOUR_LOGIN_NAME. Note the YOUR_COMPUTER_NAME, since we are using Personal ArcSDE on SQL Server Express, your local PC is likely the server.
10) - Click Next and finish the installation. You can also close the ArcGIS for Desktop installation window now, as you no longer need it. Your database should now be enabled for creating geodatabases
11) - To create a geodatabase, DON'T USE THE "Create / Enable Enterprise Geodatabase" TOOLS!!!
I can not emphasize this enough. As the name of the tools already indicates, these tools only work against "enterprise" databases, not on SQL Server Express!
12) - To create an ESRI Geodatabase on SQL Server Express, simply create a new Database Server(!) connection to the SQL Server instance in ArcCatalog using the Add Database Server option under Database Servers in the Catalog Tree of ArcCatalog.
NOTE: I wrote Database Server, not Database Connection. You must first create a Database Server connection, as only a Database Server connection contains the context menu option to create a New Geodatabase, as in step 13).
13) - Now right click the new Database Server connection, and choose New Geodatabase from the context menu.
Yes, it is that simple! No hassle with an authorization file as in the "Create / Enable Enterprise Geodatabase" tools. The authorization of ArcSDE Personal Server forms an integral part of your ArcGIS for Desktop license, and was applied in steps 4) to 10).
NOTE 1: In order for this step to work, you must have an ArcGIS for Desktop Standard or ArcGIS for Desktop Advanced license. This doesn't cost you anything extra with an ArcGIS for Home Use license, it is just another licensing scheme you need to activate / authorize from the ArcGIS Administrator included with ArcGIS for Desktop. In Desktop Basic the New Geodatabase option is disabled in the context menu.
NOTE 2: After you have created the geodatabase via the Database Server connection, you can now also use the Add Database Connection option in ArcCatalog, to create a new Database Connection to your geodatabase.
Congratulations, you have just created your Personal ArcSDE / Desktop Geodatabase in SQL Server 2012 Express!
Hi Marco,
I am following your instructions and thank you they have been very helpful.  Just a question, I already have ArcGIS for Desktop installed, do I need to uninstall then reinstall to get the option for step 7?  Right now, I am able to connect to my instance, but when I use the "new geodatabase" option then I get an error, so I wonder if it has to do with me skipping step 7. My license is "Advanced". [ATTACH=CONFIG]28981[/ATTACH]
MarcoBoeringa
Hi Marco,
No, you shouldn't be forced to completely uninstall and re-install ArcGIS for Desktop (at least not with the ArcGIS for Desktop 10.2 install part of the ArcGIS for Home Use program, on which I based these instructions) in order to get this option of enabling the SQL Server Express database to store a geodatabase.
It looks like the enabling of the database for storage of a geodatabase failed, and hence you can not use the New Geodatabase option successfully.
A couple of questions:
- You did see the option "Enable geodatabase storage on SQL Server Express" listed in the dialog I referenced in step 7)??
- You did perform step 4-10, including 7? You seem to suggest you skipped those. You MUST perform these steps, because it is exactly in those steps, that you enable / license the SQL Server database to store ESRI Geodatabases. If you don't perform these steps, the New Geodatabase option will fail, because you are not licensed yet to create the geodatabase (which is exactly your error message).
- You are using SQL Server Express as the backend database, do you? Not an enterprise class SQL Server database? These instructions are for creating databases in SQL Server Express, not an enterprise class SQL Server database.
*** EDIT ***
I am realizing your main confusion is about the ArcGIS for Desktop installation needing to be started at step 4). The ArcGIS for Desktop installation actually consists of multiple independent modules, and the ArcSDE for Microsoft SQL Server 2008 R2 Express option is one of them. So even though you must start the ArcGIS for Desktop installation at step 4), this doesn't mean you need to re-install entire ArcGIS for Desktop to enable geodatabase storage.
In fact, you just have to choose / run the module for the ArcSDE for SQL Server Express installation, as described in steps 4-10. This option is available straight from the main installation window that opens once you start the installer.
And even for this module, you will bail / opt out of the SQL Server 2008 R2 Express installation, as described in step 7), just continuing to enable / license your existing SQL Server 2012 Express in steps 7-10 (assuming you do pre-install V2012 as in step 1).
