Output feature shift from input data after Dissolving
2492
12-01-2016 02:59 AM
MuhammedThouseef_MT
Input line featureOutput line feature(Red) Please note the shiftHi All,
I have line feature class with different lines. When I am performing Dissolve operation, the  generated output feature class (Same geodatabase & same coordinate system) showing a minute spatial difference from the input features. But I want to get the output without changing the location.  I'm here with attaching the input and out put screen sots for your review. Please help me to solve this issue.
NeilAyres
The usual questions here...
How small is the shift you illustrated?
What is the coordinate system? What type of db? What version?
MuhammedThouseef_MT
Hi Neil,
Shift is very minute :0.000161 Feet
Projected Coordinate system:WGS_1984_Web_Mercator_Auxiliary_Sphere
File geodatabase, Feature class (ArcGIS Desktop 10.4.1)
NeilAyres
I thought that Web Merc was a mteres based system, not feet.
But either way, that shift is very tiny, about 0.05mm.
You are probably hitting the limits of numeric resolution there.
Just zoom out a bit and ignore it.
ChrisDonohue__GISP
I agree with Neil Ayres in that the shift is not of any major consequence and is likely at the limits of the software to resolve.
Note that if you are looking at the linework at a scale of less than 1:1 in ArcMap that what is seen is often a visual artifact.  ESRI Tech support has confirmed that below 1:1 there can be visual results shown that are not representative of the data.
Strangeness - gaps unintentionally created while editing
One way to check if the depicted shift is of any consequence is to evaluate it against the XY Tolerance setting for the data.  If the shift is below the tolerance, then the feature are considered coincident even though they seem to be off by a small amount.
ArcGIS Help (10.2, 10.2.1, and 10.2.2) (scroll down to Tolerance section)
Tolerance\resolution concept, (GeoNet discussion on XY Tolerance and Resolution)
Chris Donohue, GISP
