Oracle Tracing & Bind Variables
3966
10
02-21-2011 06:35 AM
NathanielWingfield
Oracle tracing with TKPROF is the recommended way to troubleshoot data access performance problems with SDE. Unfortunately, queries that differ in any way are considered "different" and summarized independently. For our long-running geoprocessing task, millions of queries like this are generated:
SELECT A, B, C FROM TABLE WHERE (OBJECTID = 123);
The TKPROF output for this query shows stats for EVERY SINGLE CALL of this type, because the OBJECTID differs in each case. For example:
call     count       cpu    elapsed       disk      query    current        rows
Parse        1      0.00       0.00          0          0          0           0
Execute      1      0.00       0.00          0          0          0           0
Fetch        1      0.00       0.00          0          3          0           1
total        3      0.00       0.00          0          3          0           1
SELECT A, B, C FROM TABLE WHERE (OBJECTID = 124);
etc...
Millions of stats like this are pretty useless. They need to be summarized for every query that follows the pattern "SELECT A, B, C FROM TABLE WHERE (OBJECTID = x)".
If Oracle bind variables are used, however, the TKPROF output is more helpful. For example:
INSERT INTO TABLE (A, B, C)
VALUES
 ( :a1, :a2, :a3)
Parse      687      0.01       0.01          0          0          0           0
Execute    687      0.08       0.10          4        689       4851         687
Fetch        0      0.00       0.00          0          0          0           0
total     1374      0.09       0.12          4        689       4851         687
So the question is: is there any way to force ArcSDE/ArcObjects to use bind variables when constructing Oracle queries?
If not, how do you recommend performance tuning for a long-running geoprocessing routine like this?
ForrestJones
Hi Anthony,
Yes, you are correct. An in list will be used and performance would be better than sending multiple queries for every objectid requested. It would also cut down on the round trips to the database.
