Oracle Spatial data on ArcMap
438
08-15-2012 09:57 AM
MM2
I have my geometric data in Oracle. My data was previously converted from the ESRI Shape files to Oracle for our clients.
When I connect to the Oracle Server in ArcMap, I can view all my tables but I cannot display them in a map format.
I am very new to Oracle spatial so your help would be very much appreciated.
TravisVal
Have you been able to display the map yet?
If not, what versions are you using?  Does your layer have a spatial index (check on the properties tab)?  How are you accessing the layer(add data button or through a query layer)?  Are you getting any error messages (either in ArcMap or in the SDE logfiles)?
Travis
