Oracle Security Solutions and ArcSDE Geodatabase
1180
03-09-2014 08:26 AM
EmadAl-Mousa
is there any official link from ESRI that provides what are the Oracle Security Solutions that can be implemented over (certified with) ArcSDE Geodatabase ?
such as Oracle virtual private database, Label Security, encryption, database vault.....etc
NidhinKarthikeyan
Honored Contributor
Oracle Database Security Solutions is not formally supported by Esri. Those security solutions are more into RDBMS level and I believe that it won???t work with versioned data. Recommended to use it in simple feature class and while you work on Relationship Classes and Domains, things become complex.
NidhinKarthikeyan
Honored Contributor
Take a look at ArcGIS Enterprise Security whitepaper:
http://www.esri.com/library/whitepapers/pdfs/arcgis-security.pdf
Also go through Implementation section (Page 39-41).
Delivering Secure ArcGIS Solutions.
EmadAl-Mousa
Thanks Nidhin,
all what i have seen so far is only presentation material. there is no "recent" white paper about ArcGIS Security which is a very important topic for the enterprises !
NidhinKarthikeyan
Honored Contributor
