postgresql error
1648
03-03-2014 10:20 AM
TateM
hello all, I have an error and looking for some guidance to resolve this error.
I'm using Add Query Layer to pulling a Query Feature Class from an PostgreSQL spatial database.  And when I open up the attribute table to view all the records it gave me an error.
"Error reading OID from table. Reading rows has been stopped. Check that the datasource is valid. Linestring or poly boundary is self-intersecting".
I found a knowledge base article http://support.esri.com/zh-cn/knowledgebase/techarticles/detail/40896 , but I'm not really sure what to make of this.
Please any help or directions would be greatly appreciated.  TIA.
AsrujitSengupta
Copy that Feature Class to a File gdb and run 'Check geometry" tool on that. It should list all the features with invalid geometries.
Then you can either go through the features reported in this and correct them OR run the "Repair Geometry" tool, which will repair these. Then copy this corrected FC back into the postgreSQL database and try again.
However I would suggest you read about these tools a bit before executing them!
Checking and repairing geometries:
http://resources.arcgis.com/en/help/main/10.1/index.html#//001700000042000000
Check Geometry (Data Management):
http://resources.arcgis.com/en/help/main/10.1/index.html#//001700000034000000
Repair Geometry (Data Management):
http://resources.arcgis.com/en/help/main/10.1/index.html#//00170000003v000000
TateM
Thanks Asrujit.
Is there anyway in ArcMap that we can tell it to IGNORE the error and keep on drawing or displaying it?  Because other layers who have the same error works fine(displaying/drawing) with the only exception is that these layers have less record/rows than the  one that  broke down and gave the error.
