Oracle sde direct connect "No ArcSDE server license found"
2444
04-03-2012 06:33 AM
KyleDixon
Using ArcDesktop 10.1 using direct connection to Oracle 11.2.0.1 I'm getting error:  "No ArcSDE server license found".
The connection worked fine up until this morning. I was a beta tester, but everything I'm using is a 10.1pre license.
I have a call in to tech support, but they are apparently very busy this morning.
KyleDixon
The database was created with 10.1 beta so it had an Apr 2 expiration date.
Solution:
Run Toolboxes\System Toolboxes\Data Management Tools.tbx\Geodatabase Administration\Enable Enterprise Geodatabase
Select the SDE connection in your "Database Connections" folder
then select a valid authorization.resps file for ArcServer
