I've been familiar with ArcObjects' requirements for a unique registered rowid columnsince 8.0 went beta. If you look at my view construction commands, both here and in theold Forums, you'll see that I always take the objectid column from the many side, which circumvents the Knowledge Base issue. Note that it's not ArcSDE which has an issuewith non-unique objectids -- Desktop has to juggle the relationship between attributemetadata and graphics in the display pane; without a unique feature key to associatethem, that task becomes nearly impossible....If a spatial view with a unique registered rowid column doesn't behave properly while using a supporteddatabase build, please bring it to the attention of Tech Support. - V
BTW: Robert - You probably don't need to place the layer in load_only I/O mode before a truncate and append -- the 'init' option of 'sdeexport' does the truncate, load_only, insert, and normal_io in one command.
C:\Incoming>more 1toMone.txt 1toMone.ctl 1toMmany.txt 1toMmany.ctl | cat :::::::::::::: 1toMone.txt :::::::::::::: AAAA|box:-10,6,-6,10 BBBB|polygon:6,6,10,6,8,10,6,6 CCCC|circle:0,0,3 DDDD|polygon:-6,-6,-10,-6,-8,-10,-6,-6 EEEE|box:6,-10,10,-6 :::::::::::::: 1toMone.ctl :::::::::::::: COORDSYS GCS_WGS_1984 COORDREF_XY -210,-120,1000000 EFLAGS "na+" DELIMITERS "|" REGISTER objectid COLUMNS objectid Sequence() - 10 N keyval String - 4 N shape Shape - 1 Y END :::::::::::::: 1toMmany.txt :::::::::::::: AAAA BBBB CCCC DDDD EEEE BBBB CCCC DDDD EEEE CCCC DDDD EEEE DDDD EEEE EEEE :::::::::::::: 1toMmany.ctl :::::::::::::: REGISTER objectid(SDE) COLUMNS objectid Sequence() - 10 N keyval String - 4 N END C:\>asc2sde -o create -l otm_layer,shape -g 5 -f 1toMone.txt ASCII to ArcSDE 10.0 Loader Utility Thu Dec 02 07:57:28 2010 ------------------------------------------------------------------------ Results: Records read: 5 Rows created: 5 Insert time: 218.00 ms (22.94 TPS) Elapsed time: 2.95 secs C:\>asc2sde -o create -t otm_table -f 1toMmany.txt ASCII to ArcSDE 10.0 Loader Utility Thu Dec 02 07:58:53 2010 ------------------------------------------------------------------------ Results: Records read: 15 Rows created: 15 Insert time: 16.00 ms (937.50 TPS) Elapsed time: 422.00 ms C:\>sdetable -o create_view -T otm_view1 -t otm_layer,otm_table -w "otm_table.keyval = otm_layer.keyval" -c otm_table.objectid,otm_layer.keyval,otm_layer.shape ArcSDE 10.0 for SQL Server Build 775 Fri Sep 17 11:45:27 2010 Attribute Administration Utility ----------------------------------------------------- Successfully created view otm_view1. C:\>sdetable -o create_view -T otm_view2 -t otm_layer,otm_table -w "otm_table.keyval = otm_layer.keyval" -c otm_layer.objectid,otm_table.keyval,otm_layer.shape ArcSDE 10.0 for SQL Server Build 775 Fri Sep 17 11:45:27 2010 Attribute Administration Utility ----------------------------------------------------- Successfully created view otm_view2. C:\>sdequery -t otm_view1 ArcSDE 10.0 Generic Query Tool Thu Dec 02 08:04:56 2010 ------------------------------------------------------------------------ 1 objectid: 1 keyval: AAAA shape: Area shape (1 part, 5 vertices) 2 objectid: 2 keyval: BBBB shape: Area shape (1 part, 4 vertices) 3 objectid: 3 keyval: CCCC shape: Area shape (1 part, 37 vertices) 4 objectid: 4 keyval: DDDD shape: Area shape (1 part, 4 vertices) 5 objectid: 5 keyval: EEEE shape: Area shape (1 part, 5 vertices) 6 objectid: 6 keyval: BBBB shape: Area shape (1 part, 4 vertices) 7 objectid: 7 keyval: CCCC shape: Area shape (1 part, 37 vertices) 8 objectid: 8 keyval: DDDD shape: Area shape (1 part, 4 vertices) 9 objectid: 9 keyval: EEEE shape: Area shape (1 part, 5 vertices) 10 objectid: 10 keyval: CCCC shape: Area shape (1 part, 37 vertices) 11 objectid: 11 keyval: DDDD shape: Area shape (1 part, 4 vertices) 12 objectid: 12 keyval: EEEE shape: Area shape (1 part, 5 vertices) 13 objectid: 13 keyval: DDDD shape: Area shape (1 part, 4 vertices) 14 objectid: 14 keyval: EEEE shape: Area shape (1 part, 5 vertices) 15 objectid: 15 keyval: EEEE shape: Area shape (1 part, 5 vertices) 15 rows found in 375.00 ms C:\>sdequery -t otm_view2 ArcSDE 10.0 Generic Query Tool Thu Dec 02 08:05:04 2010 ------------------------------------------------------------------------ 1 objectid: 1 keyval: AAAA shape: Area shape (1 part, 5 vertices) 2 objectid: 2 keyval: BBBB shape: Area shape (1 part, 4 vertices) 3 objectid: 3 keyval: CCCC shape: Area shape (1 part, 37 vertices) 4 objectid: 4 keyval: DDDD shape: Area shape (1 part, 4 vertices) 5 objectid: 5 keyval: EEEE shape: Area shape (1 part, 5 vertices) 6 objectid: 2 keyval: BBBB shape: Area shape (1 part, 4 vertices) 7 objectid: 3 keyval: CCCC shape: Area shape (1 part, 37 vertices) 8 objectid: 4 keyval: DDDD shape: Area shape (1 part, 4 vertices) 9 objectid: 5 keyval: EEEE shape: Area shape (1 part, 5 vertices) 10 objectid: 3 keyval: CCCC shape: Area shape (1 part, 37 vertices) 11 objectid: 4 keyval: DDDD shape: Area shape (1 part, 4 vertices) 12 objectid: 5 keyval: EEEE shape: Area shape (1 part, 5 vertices) 13 objectid: 4 keyval: DDDD shape: Area shape (1 part, 4 vertices) 14 objectid: 5 keyval: EEEE shape: Area shape (1 part, 5 vertices) 15 objectid: 5 keyval: EEEE shape: Area shape (1 part, 5 vertices) 15 rows found in 250.00 ms C:\>
